GeeTee
- Jul 14, 2014
- 20
Was out in the bay yesterday, had to get a TOW home by a Jon Boat with a 40 horse on it - i took hours out of their fishing time to assist me. Thank goodness there are "good guys" out there or i would have had to use my trolling motor to get to the ramp.
I did some troubleshooting, no fire, batteries are fully charged every now and then it would seem as if it wants to fire but doesnt. This happens for a split second then goes away. I replaced spark plugs with new ones as older ones seem to be a little fouled. Still the same issue. I then removed the spark plug wire from each cylinder and tried arc against the engine to check spark, nothing. Fuel pump works too, i tested that. Im thinking its the CDI unit, or is this indicating its the stator?
How to be sure?
How to be sure?
