i have a 1971 60 hp johnson with electric shift. 3 cylinder, 3 carbs. the engine cranks cold and runs fine. it will idle out of the ramp with no trouble. i go to wot for a while and do the usual running and then it won't idle. in gear i can bring it down to slow speed with no problems apparent. then i can drop it to idle in gear and it will start running rough and will eventually die. if i bring it to neutral from running, it will die. i have to raise the neutral throttle to crank it and then engage the drive while the idle throttle is up to get moving. it seems i can bring it back home and after its been sit for awhile, i can crank it with the muffs and it will idle fine. i have a new tank, vent is open, bulb is hard, and pretty sure the fuel pump is fine because it runs fine at higher throttle. please help, any advice here would be greatly appreciated.
