Bought a 1958 Evinrude electric start with pressurized tank for 80 bucks. Guy said it runs but lower unit was off and he said a bearing was out. Well ... can't see how it ran since when I tested it at home there is no spark. Pulled lower unit apart and all 3 gears have chips out of them. Skeg bent. Put some penetrating oil in cylinders laid it down and let it sit overnight. Then put some oil in cylinders and let sit. Put it on the stand and let it sit overnight for it to drain out. Pulled cord a few times to get some of the oil out and then did compression test. 120 to 100 on bottom.
My Questions
1 - Worth rebuilding or is this a parts motor ? (probably cost $150 - $200 to rebuild lower unit and $100 on points etc.)
2 - Can the skeg be straightened?
3 - Is this decent compression on a motor this age? I know the oil probably helped the compression a little but didn't what to score the walls.
Thanks
My Questions
Thanks
