Hi, folks. I've searched the forums and found great info on replacing my impeller, which I have successfully done. However, I'm having a very hard time reattaching the shift linkage. If I leave the shifter in forward, I have enough room to work between the midsection and lower unit and I can screw the bolt back into the linkage. But if the lower unit shift rod is pulled up, I need to be in neutral in order for it to work properly. I don't have enough room to get in there when I do this. Please help!!
