Boobie wanted to say thanks to you, I got home from offshore and pulled the clip out and took out the manual release valve and sure enough the o-ring was not even on there, I went to my dealer got another o-ring installed the manual release and went to the launch, problem solved motor will not tilt up when I apply throttle to it thanks again.
