I noticed that my 1999 Johnson 115 PLEEM is getting kind of hard to start. The engine even has a hard time starting on occasion after running for a good while and then sitting for about an hour. On every outboard I have owned I have always had the luxury of just disconnecting the fuel line and running the engine till all fuel in carbs in burned up before storing for anymore than a week of so. My theroy is that fuel and oil mix is sitting in the carbs and gumming them up. The outboard on my boat (which i have only recently bought a month ago) has one single tube that holds all the lines and runs into the cowling. I took a look in there to see if the engine perhaps had the OEM style OMC fuel disconnect and did not see one. I am thinking of putting some sort of ball valve inline on fuel line so that I can shut fuel off before storing the boat for some time. Am I missing something here and there is an existing fuel shut off that I don't know about? I am guessing the line is just plumbed straight to the VRO system but I am not an expert on these things. Any advice on this is much appreciated. Thanks
