chi_town60608
- Sep 9, 2014
- 22
I have a 1964 28 HP Johnson model RX-12, Serial # J2455104. It was wired for remote control and start. I am going to use it with the tiller and would like to wire it with a start switch on the outboard itself. I have looked over different diagrams and I haven't found one that fits the situation I'm wanting. I want to put a push-to-choke, 3 position key switch on the outboard. I will move the solenoid out of the junction box and mount it somewhere on the block. I will also be installing a lanyard kill-switch. I have created a diagram/schematic and filled it in as best I could. I have included the numbers in the diagram to help any of you explain to me which ones need to be connected and/or added. I believe I'm correct in its wiring thus far, but I'm not sure how to wire the vacuum cut-out switch. In the diagram, I've used a 6 pole switch so I can add accessories to the wiring later. If I decide against that, a 5 pole would work, correct? If so, will it change the wiring? Lastly, to get the battery connection into the outboard, can a trailer connection be used? If yes, can I use a 2 pole connection or should I go with a 7 pole connection and just wire two of them? I will be going with a round connector in either case with 4 gauge wire.
I appreciate all suggestions and will answer any questions any of you might need.
Thanks,
chi_town
Thanks,
chi_town
