Enginefixer
- Sep 11, 2014
- 9
I am a newbie to all this. I bought an older boat and motor combo, and the engine is a 1979 100 hp (100ML79S)Johnson. I sat for a couple of years but was drained and flushed prior to putting away. Got it home, fresh gas and oil, changed the oil in the lower unit and test fired. Seemed to run great. Changed the gas line, as the old one was hard as a rock, and added a filter. Once again the engine ran great on the flusher, no overheating, good flow out the pee tube etc. Once warmed up will fire at a touch of the key. Brought it to the river and dropped it in the water. Ran like crap, wouldn't idle even after running in warm up for a bit. Thought maybe I was sucking air. Checked all the fittings, changed the hose to tank and hose to engine connectors, tightened all the clamps etc. Ran again at the house and sounded like I had a winner. Brought it to the river again, and as soon as it got wet, same thing all over agian. Started fair, idle went down to nothing and died, pian in the butt to restart. Drug it home again, and here I sit. Any and all ideas would be much appreciated.
