KRH1326
- Sep 22, 2007
- 491
Hello All,
I have two identical motors. Motor A threw a rod, and was sidelined. Was using motor B, until a head gasket failed. Opened up motor B, to install new head gasket, and found cracked cylinder. Completely stripped blocks A and B down to case halves.
Rebuilt existing motor from case halves A, bearings and crank B. Best pistons and rods from both A and B, all with new rings.
Completely broke down and cleaned carbs.
Verified and tested all ignition components.
Complete powerhead gasket kit.
All assembled, following actual factory ( not seloc or clymers, etc.) manual.
A 30 yr. outboard mechanic acquaintance told me to increase the main jet size by one, for problems common to the cross-flow motors. I told him my budget was already blown, and he then advised me to run a #52 bit, by hand, through the jets, after consulting size charts and part numbers. This bit barely removed any material at all.
Runs in driveway with lower end in a tank/tub with muffs simultaniously. The tub part just catches the water and keeps the lower unit submerged, to help with exhaust sound.
Set up all of the linkages, as per manual, and it starts and runs ( very smokey from the assembly oil and the double oil/gas for break in) and I can slip it into gear briefly. All seems well.
At the dock, I can start it, with high idle, but it stalls out when the throttle lever is returned to nuetral ( single lever top mount binnacle) to engage forward or reverse, every time. Extremely frustrating ride home.
In driveway, with muffs, and lower submerged.... it runs fine... still smokey (see above) and shifts fine...
I checked timing again via #1 and #2 cylinders, and both are on the money. I then hooked the timing light up to each and every spark wire, to make sure that each coil was in fact firing.
Scratched my head, threw my tools across the yard, found and picked them up, grabbed a smoke and fresh cup of coffee, and sat down and thought...
A) Can the higher water level on the motor, at the dock actually in the water, actually make some sort of difference? I ask this because it seems to be the only difference between success in driveway and dockside failure.
B) How can I detect if each cylinder is actually getting fuel/air and really "firing"? Even though I know there is power to spark plug?
C) Can the one size jet increase be the cause?
D) What am I missing?
Any help and input would be GREATLY appreciated. ( Mechanic friend is several states away, or I would ask his help.)
Kenny
Kenny
