wallyevs012
- Jul 4, 2003
- 46
Just put new Michigan Wheel prop on my '96 Evinrude 15hp motor. I used white lithium grease applied liberally to shaft and splines. The manual does say use OMC Triple guard grease for this. Is lithium OK? I ran it with muffs on for 4 minutes and shifted gears, all was OK, but I did note grease dripping out of prop a few minutes after I shut it down. Is this normal? Thank you, Wally
