burnt clutch
- Jul 3, 2012
- 38
I'm back to tinkering with my TN-28 and I'm noticing some things. First, when I run it at a steady speed, I notice that the RPM's surge a little. Is this normal with these engines, or indicative of another problem? Also, when I first start it up, there is a steady stream of cooling water coming out of the elbow for the cooling line under the cylinder. When the engine warms up the stream gets choppy and sometimes turns to steam. Is this normal or should I be checking something out? Thanks in advance for any advice!
-Karl
-Karl
