Re: 3 h johnsn wont run with the bladder in
on the bottom of the carb you will find the gravity feed gas line going to the chamber assembly(houses the float) which is controlled by the fuel cut off switch, the other line comes out and runs up to the side of the engine...this line has a plastic screw fitting on the chamber assembly which houses the "bladder" it looks like a little orange ****** it has a slot in the top and it seems to fill up with gas ...this line coming from the side of the engine pushes air toward the bladder when the engine is turned over...is this part of the fuel pump assembly?
