Need help again guys ......so my evinrude is a 1987 88 hp 4 cylinders ...have had starting problems so i have Checked spark. And is good new spark plugs new wires new rectifier the power packs look clean no sings of burnt coils also look ok ...but the thing still gives me problems when in the water ones i get it fire. Up its ok works fine but once cut off it will take a while some times it fires up and when puting it in to gear dies down then its like it just cranks and dont starts . I try pumpin the primer bulb and i think it helps a litlle but not sure because after trying and trying it finelly starts. ....but you know when you out there fishing and want to move to a diferent spot its kind of anoying dealing with some like this ....ok thanks in avanced for your help its really appreciated thanks
