50 hp johnson charge coil
tblshur
i have a j50tlco model johnson top cylinder was not firing or maybe some, the charge coil pt # 0581670 and sensor 0583387 had black tar running out of the bottom of them motor running good now. my question is what would cause this to happen and would i need to replace something else or check something else to prevent this from repeating. thanks for all answers:joyous:
tblshur
:bump::bump: any ideas what may cause this problem:confused::joyous:
tblshur
old man age works on everything, at least now i feel better that maybe it will be alright , enjoy the motor. thank you very much for your responce.:joyous:
tblshur
