Matthewj500
- Aug 30, 2014
- 2
I fairly inexperienced with this motor, and do not have the owner manual with it. It had been running fine before about 6 month storage. Ran it at home prior to a lake trip, and ran fine. At the lake a steady warning buzzer went off at the start, so turned it off and ended up running around with trolling motor by dock for a bit. Then tried it again, and it ran fine with no buzzer. Then stopped for a bit to fish, and when I started it, the buzzer was back.nall guages appeared normal, good water flow. I figured you all here would have a good idea of where i could start.
