Johnson Outboard
- Jul 15, 2013
- 7
I have a 77 200 Johnson that I have owned for 30 years. A few years ago it started this thing were you start it cold, Idles and runs good up to normal 5500 rpm, all good. You shut it off for maybe 15 to 30 minutes, start it, idles fine, go to take off and it dies like lack of fuel. You can gradually give it throttle and choke it until it will gain rpm. Once re-established it runs great until you shut it off then its the same thing all over again. Seems to be worse the warmer the ambient air temp. I have rebuilt the carbs, replaced all fuel lines, fuel pumps, fuel selector switch, base gasket, check the reeds (boyesen reeds in good shape),Tanks are vented good and fuel pick-ups tubes are good. It runs at a steady 145 degrees. The motor has about 800hrs on it. I have installed the later model thicker head gaskets and it has 100 to 105 lbs of compression in all cylinders. The thicker head gaskets drop the compression from the stock 115 to 120lbs. The local boat mechanic thinks it could be the sealing rings on the crankshaft between the cylinders are worn to the point that once its warmed up and shut off its allowing the fuel charge to leak past. I just can't help to think its something else do to the top carb doesn't have a choke plate. I would hate to spend the $ replacing the sealing rings only to have it have the same prob. Any Ideas out there? Thanks for responding
