The charging system is putting out 12.2 volts and will not go any higher when I increase the throttle. I replaced the rectifier. Still the same. Cleaned all connections. I tried to check the AC voltage from the stator while the motor was running, the gauge on the meter would only keep flashing. I thought I might have had a broken stator wire. I removed stator and bench tested it. Using a OHM meter I have continuity from both yellow starter wires. I tested both the new and old rectifiers and got the same readings. My question is should I put it back together and see if it is charging or can anyone lead me in the right direction. The engine runs great other than no charge, Also can someone tell me the correct torque for the fly wheel nut. Thanks.
