Fuel mixture Evinrude 30HP 1990
rocketman007
Hello to all! First, sorry, my english is not perfect, but i´ll do my best.<br /><br />I bought a used motor, evinrude 30hp, built 1990. The seller told my to use 1:100, but it seems, that the motor runs hot. What´s the rigt fuel-mixture? 1:100 or 1:50? Motor-Number: BE30BAESS.<br /><br />There´s no pdf-manual? Would be great!<br />Thanks, Volker
clanton
Re: Fuel mixture Evinrude 30HP 1990
I would use a 50-1 oil fuel mix. Check water pump first for overheat. If you still have overheat after waterpump replaced, remove head check water deflectors.
Spidybot
Guten Tag Volker!<br /><br />50:1 is way to go.<br /><br />Hopefully it hasn't been damaged by running 1% ??<br /><br />Use link bottom of this page to find a manual for the motor. <br />You'll never regret getting one...
rocketman007
Thanks for answer...<br /><br />Because i did not want to damage the motor, i used about 1:75. Overheating was just a feeling. So you are sure, 1:50 is right?<br /><br />I asked for manual, eg. technical specification, to read it "black on white". And sure the dealer is interested too. To argue i would like th have something written in my hands.<br /><br />Bye, Volker
Spidybot
Yes. You can find a manual here <br /><br />Until you get it:<br /><br />2-cyl<br />531 ccm volume<br />Loop charge<br />22,4 kw on prop shaft at 5500 motor rpm<br />Max rpm at wot is 5200-5800<br />Gear reduction is 13:26<br />One carburettor<br />4A charging capacity<br />S.L.O.W system for slowing down in case of overheat<br />Easy-pull start<br />Waterproof CD ignition<br />Optional AccuMix oilinjection<br />Weight 53,5 - 54,4 kg<br />Std. prop was 3-blade alu, 10" dia 13" or 15" pitch<br />Fuel min. 90 octane RON
CharlesW
Johnson/Evinrude did recommend a 100:1 oil mix for a short time. They issued a service bulletin to use 50:1 after they burned up several motors. The original manual probably said 100:1 and that ain't good.<br /><br />Charles
Spidybot
Right - and some oil brands talk about 100:1 as well. :( <br /><br />Still , 50:1 (90 octane and TWC-3 oil) is way to go.
rocketman007
Thanks to all! <br />That´s what I needed. The Dealer was sure and - he does´nt seem to be someone telling buls... - you told me the reason. For me it was hard to believe what´s right. <br />In Germany we have some forums too, but the number of members is quite less. So the answers come - if the come - very slow. So again, many thanks and always enough water unter your boats! Volker
Davey62
Would the 50:1 mixture also apply to OMC Model #TJ30ELCED, which I believe is a 1989 model? Thanks!
jasper60103
You should have started a new thread. Anyway, yes your motor is a 1989 and 50:1 is the correct fuel/oil mix for your motor.
