Bassinbob47
- Aug 18, 2014
- 7
Hello. I'm new to iboats and I just purchased a stratos with a 1998 Johnson fast strike 150. My problem is a common one that I have read a
lot about on this website. When I first start it up it runs great, idles and planes out perfect. After running for a while and then shutting it off to fish for a while it will then run poorly right after I start it to leave. It will bog and stall several times and eventually clear and run OK but not great like it does the first time. I have just got it back from the repair shop. The mechanic fully checked the motor and found the needles in the carbs weren't clipped on correctly. Everything else is fine. He told me to run it and if it still does it then he would take a look at the vapor separator pump. I took it out the other day and the problem still exists. My question is, Does anyone agree that the VSP is what the problem is? I have also replaced spark plugs and water separator filter. Thanks for your time.
