I have a 93 Johnson 150 Silver Star. At least OMC tells me it's a 93. Model number is VJ150ELATR, there's no A in INTRODUCES. Anyway OMC said it's a commercial engine, only difference is heavier shaft and lower unit.<br /><br />Questions - 93 motor, powerhead supposedly replaced in 99/2000. Not sure if they would have replaced VRO2 at same time. Is this oiling system reliable or should I disconnect and pre-mix? I did get a no oil warning horn once when I was at very slow idle speed for 5 or more minutes. Wife was riding in new boat and was house shopping from the water. Have never gotten any horns when running normally and can see oil is being used from VRO tank.<br /><br />Also, referring to Seloc manual for year and motor it shows that the pulse limiter hose should go to a check valve that mounted but not screwed into block. When I checked mine the valve is screwed into the crankcase like a V4 setup. Wondering if when they changed powerheads I ended up with an older or newer type than what it was replacing. Any ID numbers on the powerhead themselves that would give me that info?<br /><br />Thanks!
