I just purchased a used 1993 225 HP Johnson outboard. When the engine is all the way down (flat) it idles fine. As the engine is tilted, the propellar exhaust fills with water from the intake ear muffs and stalls. The same problem occured the last time I attempted to lauch the boat at low tide.<br /><br />Could it be that this engine isn't designed to run tilted?<br /><br />Is there anything else I should examine (have examined) that could cause this?<br /><br />ps. I have little experience in engine repair/diagnosis, but I'm hoping to learn more soon!<br /><br />Thanks in advance!!
