JuneBugJoe
- Jun 22, 2003
- 1
My recently acquired motor has a problem. Since March, it has gone through two rectifiers (it's an unregulated system) and the tachometer keeps dropping off line. This may or may not be accompanied by the volt meter going to 12 volts rather than showing a charge. <br /><br />My mechanic (who has a very good reputation) has checked out everything in the electrical system and can find nothing wrong. We though we had it narrowed down to the stator since the tach didn't fail until the engine was at cruise RPM. After changing that, the tach still quits shortly after coming up to about 4200 RPM. It usually starts working again, but there is no set pattern to it. Once the engine cools down a little coming back to the marina, it works Ok. <br /><br />Has anyone experianced this and if so, what did you find wrong? All ideas are welcomed.<br /><br />Thanks,<br /><br />Joe
