Ill try posting this again. . . (this time in the correct forum!)
I have a 1987 Evinrude 200 V6 outboard (E200TXCUC) that has been sitting for a while.
In my efforts to get it running, I was not getting ANY spark to the plugs on the motor, and ended up replacing the powerpacks (0583605) with two used ones from a local pick/pull.
The problem now is I am not getting spark to the FIRST plug on the left head, and the MIDDLE plug on the right head.
Some troubleshooting points. . .
- I have new plugs all way around (Champion QL-77JC4), so I know it is not bad spark plugs;
- I have new plug wires all way around, so I know it is not bad plug wires;
- I have switched the coil assembly on those specific plugs with working coils, so I know it is not a bad coil assembly;
- I have switched the wire coming from the powerpack to a different coil and can replicate the problem, so I know the wire coming from the powerpack is not bad;
- Finally, I have switched the powerpacks around and can replicate the problem, so I know it is not bad powerpacks;
My next thought was to pull the flywheel off and check/clean the magnets of crud?
Anybody have any additional thoughts?
Regards,
James
Regards,
James
