baconbiscut
- Jul 11, 2006
- 356
I just got this motor and I started replacing fuel lines (1/4" I don't know if that matters), I ran into an issue running a line into the fuel pump. After using a hose clamp to put the new line on it wouldn't seat properly and start spraying fuel while priming the engine. After removing the filter part of the fuel pump I noticed a small crack. I can't seem to find a replacement fuel pump for this engine, I've seen ones that look similar but I want to find the right thing. Could anybody point me in the right direction.
Thanks, Dan
Thanks, Dan
