Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1996 Evinrude 115 - just turns and turns
  • 1996 Evinrude 115 - just turns and turns
    I just bought a 1996 OMC Sunbird with an Evinrude 115. The engine hasn't been started in 2 years. It only has about 20 hrs on it. I've changed all the fluids and the plugs. When I try and start it it just keeps turning and turning and doesn't start. I've tried holding the key in for an 8 count and then tried starting and the same thing happens. I am at a loss as to why it won't kick over. The only thing I can come up with is that the way I have it on blocks the engine cannot be fully tilted in the down position it is almost straight up and down but not quite. Is there possibly a Mercury switch or something like it that would prevent the engine from starting????Any input on this engine would be greatly appreciated. I bought the boat for my 14yr old son and he is excited to get it running.Thanks so much,John
    Re: 1996 Evinrude 115 - just turns and turns
    John,You are missing one of three components:1. Spark.2. Fuel.3. Compression.Take a good look at every connection under the hood. There is one or more that have an in-line fuse in them. Check those. No spark with the blown fuse.
    • #3
      Thanks so much Djohns, I never thought of that. Wow I think this board is so cool... thanks for your input I'm sure it will help!!
      • #4
        • #5
          Thanks Specks, I know fuel is getting in but not so sure about the spark, gonna have to check that tomorrow... you guys are great thanks for the advice!!
          • #6
            John,Just thought of something!!! That engine has a kill switch.Are you sure the engine kill lanyard is on the control box or dash??????
            • #7
              Djohns, The kill switch is on the dash. it has the attachment connected to it
