Has anyone installed the TH marine hot foot pro throttle control on a 1977 Johnson 140?
My current throttle cable termination will not work to attach to the hotfoot control. I will need to order a longer cable but not sure which type to order
From what I can tell the throttle cable end at the HotFoot must be terminated with a fitting that can be slipped over the post on the hot foot. My current cable end threads through the terminator and a pinch screw is used inside the eyelet to retain the cable to the termination end
Is the throttle cable in later model 1979 and up Johnson different than the cable used on the 1977 Johnson?
