hi
i have a '75 johnson 70 horse motor i got from my nephew, we took it the other day and it stalled when shifted into gear we had it going for a bit but it only seemed to be at half power or less. he told me when he had it out last week and it ran great, said he had the carbs done but when i looked at it later the spark plugs were loose, so i'm not sure what kind of job the guy did.
i brought it home to putts around with and couldn't get it started, i checked for spark which was good, put in new fuel, then sprayed fuel mix into the carbs and it fired up. i started looking at the fuel pump and disconnected the gas line from the pump to see if it was working. while the hose was off the engine started and ran for a few seconds, i hooked the fuel line back up and it wont start unless you spray fuel into it.
the pump was pushing fuel out but i'm not sure how much it should be pushing out.
so now now i don't know if its the fuel pump or the carbs. does anyone have any ideas?
thanks
ron
thanks
ron
