I have a 1978 Johnson 85HP OB that is running on two cylinders, I swapped the power pack from the working side to the non working side, and that side started worked, so I purchased a new power pack and installed, all four cylinders worked for about 15 min. and then the power pack that I had swapped to the non working side failed again.
Any ideas what would cause a power pack to fail, I just got the motor and the power pack was out when I got it.
Thanks
Thanks
