jasonlepak
- Aug 6, 2014
- 5
Earlier this year I aquired a boat from my parents.
It's a 1981 Checkmate 17' with a 1977 Johnson 70EL77S.
The first time I took it out it flew and jumped on plane almost immediately.
The boat itself will usually get on plane between 15-20mph.
After a little while it started having power and running problems.
First time out each day it would run fine for a few minutes, then bog down badly.
So I put new OEM Champion plugs in it, completely went through the carbs with carb cleaner and compressed air and put a float/needle kit in it.
I also put in a new water pump and lower unit oil change.
I checked spark with a gap checker and the spark was bright blue and jumped a 7/16" - 1/2" gap.
The boat has a 16 gallon aluminum gas tank mounted towards the front of the boat and it has an inline high volume new fuel pump with all new fuel line.
It also has a new high volume fuel filter.
The pressure on the fuel pump is about 3-4psi, maybe a little higher.
The fuel pump on the motor was also tested to be working as it should.
I also removed the gas tank and made sure it was clean and that there were new restrictions. There is also a breather on the gas tank that does not have any check valves so I know it's not a tank pressure issue.
I also did a compression test when I changed the spark plugs and all cylinders are around 120psi.
After all I've done to it, it still lacks power.
When I take it out on the lake and give it full throttle it will max out at 3000 rpm.
When I walk to the front of the boat while someone else is driving it, it will plane out and the RPM's will reach about 4000-4500 and I will eventually get up to about 25mph.
I am pretty sure that this motor is set up for a 20" transom, but the boat has a 24" transom assuming we're measuring from the very bottom of the back of the boat to the top of the back of the boat where the motor mounts to.
I've attached a picture of how the motor sits on the boat for reference.
I'm an auto mechanic so I know a lot about engines, but not everything about 2 cycle.
I know it's getting spark, it's getting air and it's getting fuel (50:1 ratio) and I've gone through quite a few tanks of fuel already because I take it out often.
Would anyone happen to know if I'm missing something?
I also redid the throttle linkages and choke linkages and timing which at full throttle I set between 17-20 degrees according to the markings on the flywheel.
