Hello everyone. I just picked up a nice Boston Whaler with a 1977 55hp Evinrude. Prior owner thought it had an issue with the choke. It doesn't. The electric solenoid works fine. Starts and idles fine initially. Drives good. The issue is idle speed , not coming down when pulled out of gear. For example, when shifting from forward to reverse, when passing through neutral the engine revs way up , like the throttle hasn't released when it cane out of gear. Keep in mind that it runs fine in gear and idles very nice when in gear. The issue is just when pulled into neutral. I have the manual , and this model does not have an adjustable carb. high and low are set. Any thoughts as to why this doesn't rev down. How can i adjust. Thanks.
