cngodfather
- Jul 31, 2014
- 5
Hello boating Gurus! I have a 1977 johnson 115 4 cylinder with cooling issues. I plan on redoing the water pump and vernatherm. I removed the lower end and It looks like the two copper tubes from the pump to the engine do not fit snug to seal properly. Is there supposed to be a seal to seal them tight or are they supposed to fit loose to let water out? also one of the copper tubes looks a little banged up. is there a trick to round it out better? Thanks.
