SilverSS07
- Jun 13, 2012
- 266
Hey guys. I've got a 1983 Evinrude 140. Has 110 lbs compression on all cylinders and good spark (jumps 7/16's gap on all 4). It had been down on power since I changed the prop (went from 17p to 19p because hub was starting to slip on the 17) and I just assumed it was overpropped. Wasn't reaching high enough rpm, slow holeshot, etc. Then it started sputtering at idle occasionally. I finally got another 17p prop and put it on and hit the water ready to take off fast like it used to and it still didn't. Checked the coils and found one dead. Replaced it and went out again today and still doesn't have the fast holeshot and random sputtering/missing at idle. Sounds like it is spitting back through the carbs. Not sure where to go from here. I got the motor last year and went through it and replaced everything- all fuel lines, rebuilt carbs, fuel pump, water pump, head gaskets, etc. Plugs look good- maybe been out 6 times since new. It ran great until I switched to the 19p prop. I always use non ethanol, synthetic oil (premix), and star tron in every tank. Thanks for the help.
