Hey everyone! I'm new here but have been lurking for the past 2 weeks trying to get my old Johnson running with no luck.
A little history - I purchased a 12' aluminum boat 2 weeks ago and it came with a trailer and a motor. The johnson i am having trouble with. It felt like a good deal being able to pick up a boat, trailer and engine with titles for under $500. I was told that the engine sat for 2 years in a shed before i purchased it. Before sitting, the engine was supposedly tuned up and running great. I figured a good carb cleaning would do the trick. I have built and worked on quite a few automotive engines so i figured this would be a piece of cake.
First thing on the list was to clean the carb and replace the plugs. So i pulled the carb and cleaned all of the parts. The gaskets looked good so i reused them and changed the plugs. Built a wooden engine stand and set up a tub of water for the lower end to sit in. I could get the engine running and keep it running in neutral and in gear. Everything seemed to be working, water out of the little hole, spinning the prop both directions without any problems. So i mounted to the boat and set off with the girlfriend the next morning. Unfortunately, by the time the boat was in the water, the engine would not stay running. We ended up spend 3 hours on the dock next to the ramp, tinkering away trying not to drop anything in the bay. Thank the stars for the world most patient girlfriend!
So after the first failed attempt i took the boat home and put the engine back on the stand. Pulled the fuel pump to find a large amount of black, dirt-ish looking particles behind the filter screen. There is a local marina which stocks, what seems like, every johnson part available. so i called them and picked up a fuel pump rebuild kit, carb rebuild kit, a manual and a waterpump kit. Went home, replaced all of the fuel lines and fittings from the tank to the carb and rebuilt both the fuel pump and carb after a thorough cleaning. Reinstalled everything at the same settings they were at before and now cannot keep it running longer than a few seconds. Choke in or out. Very frustrating.
I have checked the compression which looked fine with the top cylinder @ 118 and the bottom @ 110. Tested for spark, and tested the fuel pump to ensure it is in fact pumping. the primer ball stays relatively firm while it runs. Pumping it when it bogs, does not make a difference. I'm begining to lean towards an ignition problem since it is the only system that has not been touched yet. I wanted to seek the advice of you all before throwing any more parts at this thing. Any and all suggestions would be greatly appreciated.
Great forum by the way! There is an incredible amount of information on here!
Here's a video of about how long this little guy will actually run.
https://www.youtube.com/watch?v=FFA6ypM0BEQ&feature=youtu.be
