58070chevyguy
- Jul 29, 2014
- 3
Have a 1984 evinrude 70hp on a pontoon I just bought. New to boats and 2 strokes so I have been doing a lot of research and fixing this thing myself. When I first purchased boat power pack was bad so I replaced that, rebuilt carbs changed plugs, and cleaned every electrical connection and coated with dielectric grease. This is when I noticed rectifier had positive wire almost corroded in half. Bought new one of eBay and now this thing gets so hot you can't touch it and with a fluke meter at battery connections I get 12.8 volts which is slightly more than when motor is not running, rpm has no effect on voltage output. Some of the other posts I have seen mention tach mine does not work should I start there can I bypass and see if it charges. I don't have a book yet been looking on eBay for a factory service one I was told to stay away from clymers. Any help is greatly appreciated .
