DAN M VAGOS
- Jul 11, 2008
- 362
Ok I had posted like 4 times on this subject but here I go agin. 99 Jonson 70 great comp 130ish on all 3 new fuel line new champ plugs with gap opened a little new termo new brain box timing set no fuel leaks fuel vent good . Ok so now my problem is when I first start boat it's idles great but when in gear the idle gets lower and lower till it stalls now please don't reply with how is my comp because the boat runs 100% once it gets past it's tantrum. I just had it at the dealer and they told me it needed a termo because it would not come up to temp then the lower pug was not fireing so they step by step checked everything and told me it needed a $350 brain box. So now days later I go to put it in the water and it still will not come off the trailer it bogs and dies. So I got it back across the pond where it was serviced and he saw it doing it the tec richended up the carbs and was like ok your all set ! Ya right next day stall after stall after stall so I whent back and he richended it up agin and 15min later stalling agine. So it's the same thing as when I first gave it to them. Now he is telling me it's the carbs. So once agin it runs great after it's fit but when I go to fish for 15/20 it starts right back up but has now power it just slowly stalls but if I rev it up first I can get it to go and please the comp is 130 because I know someone is going to say sounds like your engine is got low compression lol . So what do you all think.
