dsharretts
- Jul 28, 2014
- 17
New to me outboard - had water out tell tale one day and zero water at tell tale the next. Didn't know when water pump had been changed so I replaced the water pump - impeller was still intact and didn't look too bad (all arms intact with nothing missing).
Sprayed hose up the water line and had water at tell tale - back flushed water through tell tale hose (using small nozzle on hose) and had water coming out water line. Ran muffs on lower unit while out and had water getting to impeller (intake screens are clean) although no water coming through impeller housing with just water pressure from hose.
Used air compressor to blow back through tell tale hose and can hear air come out water line.
Re-installed lower unit and still no water at tell tale.
I'm working under the assumption that since I had no water with old water pump and no water with new water pump that, obviously, something else is going on. But with the water path apparently not being blocked (water from hose seems to get through) - where do I go next? I've pulled the lower unit and checked the impeller installation 3 times now.
It seems to me that I should get water at the tell tale with the motor running, regardless of the thermostats or current temperature.
Is there a mid point where I can check for water with the lower unit still attached and motor running?
Thanks for any help - this is my first attempt at doing my own service.
