Dukemeister
- Jul 26, 2013
- 27
Problem is no spark, have been through the CDI troubleshoot with a high quality digital peak reading voltmeter.
Stator test, brown to brown/yellow shows 0 ohms and 0 Volts, so dead.
Orange to onange/black showed 350 ohms, and produced 230 V dc peak.
Timer base all showed 2.2-2.5 M ohms, and made 4V dc peak.
No spark on any cylinder, except when I pulled the plugs, I did get a spark during cranking with the rectifier/regulator disconnected - but only once. Then it disappeared and again there is no spark.
I don't want to randomly replace parts. The stator seems dead, but what about the rectifier/regulator... any way to test at this stage?
