How are the crank bearings lubricated? I noticed a screw on the right side of motor as facing the from front, that looks like a filler point. The motor runs but after about 10 minutes get hot and siezes. I let it cool down it starts up again. I am suspecting that the crank is not lubricating properly because the piston walls look good. I cleaned and blew out all the water channels on the powerhead and verified the lower unit is pumping water properly. Thank you in advance. Respectfully, Fred
