All diagnostics are right on target..but I have about 1/4 of the power I should at high range..has anyone experienced this same problem? If so, any help would be appreciated. <br />Thanks,<br />Quay62
Post the model number as OMC did not produce a 225 in 1984. The top rpm's would help as well as what you mean by "all diagnostics are right on target". Has the motor been in storage? Are the carbs clean?<br /><br />More info please!
