i have fished off a kayak and tube but cant anymore because of back surgery. i purchasced a 16ft northwood aluminum side console with a johnson 28 spl it has sat for 10 years needs wook, it ran fin when i bought it. i have it in a trash can filled with water, new fuel lines i have it running with the top cover off but when i put cover on it dies. also i have some water coming out the front single hole i think is the exhaust and some water co i comming out of the back two holes i let it idle about 10 minutes and felt the lower section just below the engine and it was fairly hot is this normal i know the water had a black oil slick on it.
