I have a 2005 two stroke 100 Evinrude outboard (on a pontoon boat) it was running perfect,then once in a while it would stall at a slow to very slow speed //but would always restart.The last time it stalled it will not start in neutral low RPM...I have to start in neutral high RPM then very quicky shift into gear it runs perfect at higher RPM's.I checked oil level and filled,replaced spark plugs,replaced the water sep filter,replaced the throttle senor,checked fuel for water.????
