ozarkmtnhunter
- Dec 9, 2013
- 10
I am working on my ol Johnson trying to get it running good. I came across a new problem the other day. My middle cylinder was filling up with water. I have since removed the cylinder head and the exhaust manifold. The problem was defineately in the exhaust housing. The motor at one time had the gaskets replaced and who ever put it back together just glued one of the broken bolts in so of course the gasket was compromised between the water jacket and exhaust port. I have the new gaskets on the way. I broke a few of the exhaust cover bolts when removing and all the others were corroded badly. What would be the recommended replacements since the factory bolts are no longer available? Could I use 18-8 stainless 1/4-20 flange head bolts or is there something that is recommended?
