cobbcfi
- Jun 30, 2010
- 150
I thought that I had solved the metal "chinging" noises after a flywheel magnet came apart with the tips of the stator coils.. Apparently not, the sound is still there at WOT?? Also I have an internal knock in the engine, disconnecting one spark plug wire at a time for all six cylinders and restarting the engine did not get rid of the knock so it's not a missfire.. Your thoughts on the metal noise and the engine knock?? I assume that they are associated with each other but I am at a loss for ideas to diagnose?? I don't have a oil reservoir, I mix 50:1 or a quart for every 12 gallons of 87 octane that I put in. Git a fishing tournament coming August 8th and could really use the help.. Thanks guys in advance...
