scott hamilton
- May 28, 2002
- 215
[FONT="]Motor has always ran really good but a little cold blooded and sometimes would die moving from neutral to forward idle. So, I took it to have timing, link/synch and had carbs checked out to see if it would run better. Shop adjusted floats saying that the float level in this model is extremely sensitive. Also, adjusted timing. Ran great first time out after shop (prob 2 full hours of run time). Yesterday ran great for first 30 minutes. Then cruising at about 4500 rpm motor seemed to drop a cylinder (like it had a fouled plug). After a few minutes it came back on and ran great again for 20 minutes. Fished for 3 hours. Went to start and motor turned over but no fire at all (this motor had always at least fired/popped). Cranked it for a few and decided something was definitely wrong. Tilted all the way up to have a look. Removed plugs and all were wet and didn't appear fouled. Tilted back down and turned key. No power at all to anything. Changed the little 20A fuse. Turned key and fired right up and ran great the entire trip back.
1. Does the little fuse have anything to do with the ignition circuit?
2. Or do you think I had (and have) something else intermittent going on?
Thanks for all your help.[/FONT]
