Jimbo's Jumbo
- Jul 19, 2014
- 5
My 1972 85hp Johnson will start and run normally at night (it will start very quickly when I try around 10pm every time on four different days), but during the day (I usually get around to trying it at about noon and it sits in a sunny spot) it has no spark at all. I bought a new battery, checked the amp with a multimeter (it's getting 12v to the terminal and is drawing 0.07amps when motor is not running), checked the coil with the multimeter and there is almost no resistance across the coils. I didn't pull the flywheel to check the points and breakers due to the fact it starts at night and would like to avoid this if possible (but will do it if needed).
During the day I pulled the plugs and checked for spark (and get none on all four), but when I check the spark at night it sparks on all four. The starter motor also works during the day, so the circuit for the starter to turn the flywheel is working properly both day and night. It's got me a bit stumped to say the least.
Any thoughts on this one? I thought it might be a wire that heats during the day causing it to pull apart a broken wire or something, but I'm not sure. I thought it might be something with the temp sensor, but it is only attached to the hot horn according to the wiring diagram in my repair manual. If anyone has an idea of what might be causing this, any help would be greatly appreciated.
