Have a new johnson 70 4-stroke (repainted suzuki engine). It warns occasionally for over heatning (red light "hot" and signal for 10 seconds) on low rpms but cooling water is coming and the water is cold. When I turn of the motor and restart it immediatelly it works fine and no warning. Then it can run ok for a perioid of time before the error returns. My local marina have replaced the whole motor and the rpm/system check gauge to brand new ones but the error still returns. Can it be a electrical installation problem? The batteri is a 5 years old but has 13,5-15 volt when motor is running depending on rpm and the number of electric things in use such as sonar and autopilot. What triggers the warning system? Anyone else had a similar problem?
