flyingscott
- Apr 8, 2014
- 7,988
Hello I was wondering if there is a trick to getting the prop shaft out of a 1985 70 hp lower unit as mine is stuck in there I am down to the pinion gear which wont come out it gets wedged between the shift dog and the case I was told push down on the shift lever and pull on the propshaft and it should come out
