Seem to be having problems with primer solenoid. It works fine when the engine is cold...I even tested it this morning by removing one of the primer fuel lines to the top carb, and it squirted out fuel when the key switch was pressed in. Ok, this where I'm having problems, after the engine is run for about 10 mins or so, when I press in on the key switch, the primer solenoid doesn't work. I've cleaned the wire leads coming off the solenoid and coming up from the key switch...still no luck. This primer solenoid isn't that old(2009), but not sure what their longevity is either. Also replaced the key switch last year, so that shouldn't be causing any issues.
