Removing lower unit 1993 evinrude 60
fredcombs
Hello all I am having a devil of a time removing my lower unit for a water pump rebuild. I have removed all 4 bolts and the three underneath as well so that makes 7 bolts out. I have disconnected the pin on the right side if the motor and pushed it inward, still won't budge. Where else do I need to look I will post a few pictures as well. First is the shift linkage pushed I ward. Second I removed this off of the shift linkage and third is what I am looking at under the carb. Any help woukd be appreciated
