Rapid Robert
- Jan 13, 2009
- 17
~~Tell tale it putting out a good stream. After idling with the muffs on for about 3 minutes the stream becomes very hot and alarm comes on. This also happened last week when I had it in the water.
At first I thought the VRO was not working because I was not getting very much blue smoke from the exhaust. The oil line from the reservoir to the connect fitting on the motor is clear...I pumped the bulb and oil flowed freely. Not sure if oil is being mixed to the power head. I have to check the VRO pump next, but before I do...can the tell tale stream be strong and the water pump still be bad? Thanks for your help
